Max10 JTAG programming from SVF
- 7 years ago
Hi avign1,
The PULSE_NCONFIG is to emulate the nCONFIG pin function to trigger internal re-configuration during user mode (after the 1st internal configuration). This command does not work to force the CFM memory block to perform internal configuration (after the .pof programming) to CRAM without power cycle. You can refer to the following link for the JTAG instruction to force CRAM download from CFM memory block after ISP programming withou power cycle:
Nooraini
Hi avign1,
Nooraini
Yes, it works. Thank you.
I already found another solution: paste the ending lines from the SVF "SOF" file just before the last BYPASS instruction. They perform a 1500-bit boundary scan to check the state of the CONF_DONE pin, using the undocumented opcode 0x04 instead of the standard 0x05. It seems that this boundary scan (with 0x04 or 0x05) followed by the other undocumented opcode 0x03 is able to start the reconfiguration.
