10 years agoMAX10: JTAG Instruction Set - Understanding what USBBlaster is doing - later ISP
I want to do In-System-Programming for the MAX10 over JTAG. As pre-work I would like to understand what the USBBlaster is doing when using the Quartus Programmer to load a .pof-File onto the MA...
10 years agoOK - the decision to use MAX 10 is fine, it can be a fine solution. However, I maintain that supporting an upgrade path in the field, via JTAG, is shortsighted. The lack of documentation in this respect should be ringing alarm bells.
--- Quote Start --- we intended to overcome the need for the initial programming using external JTAG hardware --- Quote End --- So you need to maintain this path for the purposes of manufacturing. Why over complicate it by also giving the micro access to the same JTAG nets? You will be mightily frustrated should your prototype come back and JTAG doesn't work because you've over complicated access to, and compromised, those nets. --- Quote Start --- That is another reason for using JTAG instead of any other (user-defined) communication channel (which exist, as you assumed, btw). --- Quote End --- So you do have another route into the MAX 10 FPGA(s). Upgrade the MAX 10 FLASH via this route and leave JTAG available for manufacturing and development. --- Quote Start --- I would expect the programming routine being described there, although not easily human readable, but it is missing anyway. Do you know why? Or where I can get it instead? --- Quote End --- See the max 10 fpgas bsdl files (https://www.altera.com/support/support-resources/download/board-layout-test/bsdl/max-10.html) page for the relevant BSDL file. However, you will NOT be able to reverse engineer the FPGA programming from this. This file describes the FPGA's I/O cells and the registers that can be accessed via JTAG. It will not tell you how to use them or how to program the FPGA. If you really, really, REALLY must use JTAG then you should consider reverse engineering a Serial Vector File (SVF), which you can generate from Quartus - see here (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd07222008_677.html). These files are what a manufacturer is likely to use to program up and FPGA, via JTAG, using their own JTAG equipment. However, I still maintain the best route for upgrading MAX 10 FLASH, in the field, is via your micro<->FPGA interface, not JTAG. Good luck with your development. Cheers, Alex
