MAX10 I/Os state after JTAG operation
Hello Avi,
All configuration pins and JTAG pins in Intel MAX 10 devices are dual-purpose pins. The configuration pins function as configuration pins prior to user mode. When the device is in user mode, they function as user I/O pins or remain as configuration pins.
You can refer to Intel® MAX® 10 FPGA Configuration
User Guide for more details: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Thank you.
- avib5 years ago
Thank you AminT
None of the dual purpose pins is connected to a signal that can cause the board reset. so I don't understand why it happens.
Thank you
Avi
- AminT_Intel5 years ago
The I/O state of the pin depends on what is set by the user on Quartus. Unused pin will be in week pull (set using unused pin settings) which means HIGH state or 1. You might get this problem from the transition from configuration mode to user mode. The I/O is expected to be in HIGH mode during the configuration and the state after that will depends on what is set by the user. You might also want to check if you have reset it as reset in user mode.
Thank you.
- avib5 years ago
When we enabled the Real Time ISP in the Quartus programmer the board didn't reset.
Thanks you for your help
Avi
