fogl's avatar
fogl
6 years ago
Max10: internal reference voltage to output pin?
Hello everybody,
I am looking for a way to conect the Max10 internal reference voltage to some output pin. Can this be done?
Klemen
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    If it so, i would suggest to use 1 of the I/O pin to supply a constant 2.5V to the OpAmp input.
  • fogl's avatar
    fogl
    Just to use 2.5V reference voltage for the OpAmp input.
    YuanLi_S_Intel
    It is not possible as the vref input pin is used for IO buffer. May i know what is the reason to ouput vref voltage to external device?
  • fogl's avatar
    fogl
    Thank you for your reply. Maybe my question was a bit vague.
    I would like to output the internal Vref voltage to be accessed by some external cicuit.
    YuanLi_S_Intel
    We have Reference Voltage Pin (VREF) available in MAX10. However, it is meant for some I/O Bank that requires reference voltage for input operation.
