patrick03
4 months agoMax10 FPGA Programming with .pof file
Hello All, we are using 10M16 FPGA in our design. Observation is that we are able to program the FPGA using .sof every time but .pof gets installed on most boards 8/10 times and on few boards fails ...
FvM
4 months agoHi,
did you try to reduce JTAG frequency of USB Blaster II in Programmer Hardware Setup? If this doesn't help, there may be a problem of TCK signal quality with your PCB design, causing crosstalk of other clock signals or ringing TCK edges. A small capacitive load (10 - 20 pF) at TCK near FPGA can help in some cases.
Frank
