11 years agoMAX10 Flash Memory specifications
There is some inconsistency between the various MAX10 documents and what Quartus states for the amount of User Flash Memory (UFM) that's available. As an example, I've been looking at the 10M08...
9 years agoThat's O.K. so far but obviously didn't answer my question. I was referring to your previously point that using the dual compressed image scheme might fail one day if the design grows incrementally. I'm not talking about junk code but well considered logic that can't be easily reduced. In Cyclone III compression metrics, I'm quite sure that 72% will be hardly reached, MAX 10 is effectively Cyclone III/IV logic core, but may be the expectable compression factor size of a "full" design is different though.
