11 years agoMAX10 Flash Memory specifications
There is some inconsistency between the various MAX10 documents and what Quartus states for the amount of User Flash Memory (UFM) that's available. As an example, I've been looking at the 10M08...
9 years agothe size of programming file will change based on your fpga usage.datasheets can not predict how much fpga you have used.and they did not bother to set up a table for 50% used scenario, 60%.. and so on. so trial and error is i guess all that is left to us. or i am mistaken and there is some hidden way/tool that will help to solve this problem. never worked on it and i don't know. try checking programming file size, and compare it to CFM0 capacity. if something delete some logic gates, recompile and recheck. ...i guess............
