11 years agoMAX10 Flash Memory specifications
There is some inconsistency between the various MAX10 documents and what Quartus states for the amount of User Flash Memory (UFM) that's available. As an example, I've been looking at the 10M08...
9 years agoReally?
So you think that at some point in the design process there is a likely chance that the compressed image will not fit into CFM 0 block any more? Thinking forward that implies that the "dual compressed image" mode where the images are stored at fixed locations (start at CFM0 and CFM1 respectively) cannot safely be used? And as there is no "dual UNcompressed image" mode available this means that remote updates should not be done on Max 10 devices at all? I've never read about such limitations which would severly impact my own current design. Best regards, tfranke
