11 years agoMAX10 Flash Memory specifications
There is some inconsistency between the various MAX10 documents and what Quartus states for the amount of User Flash Memory (UFM) that's available. As an example, I've been looking at the 10M08...
9 years agouuhu, and if you configure it in "Single compressed image" mode you will have 1376 Kbites of UFM under your command. but i don't see real reason why to use compressed mode. because sooner or later your project will fill the MAX10 and you will have to write full sized configuration file.
