11 years agoMAX10 Flash Memory specifications
There is some inconsistency between the various MAX10 documents and what Quartus states for the amount of User Flash Memory (UFM) that's available. As an example, I've been looking at the 10M08...
11 years agoin the ordering code 10M08DAF484C8GES you see DA on sixth and seventh position describing special key features of the device. this is one of 6 possible variations of max 10, which goes like this:
MAX 10M08 ________________ USER FLASH BITS SC single supply, compact features 262144 bits SF single supply, flash features 2555904 bits SA single supply, analog features 2555904 bits DC dual supply, compact features same as SC DF dual supply, flash features same as SF DA dual supply, analog features same as SA
