9 years agoMAX10 flash memory address mapping
Hi, I have instantiated an Altera on chip flash memory in a code to perform field upgrade in a 10M08 device. 1. Please clarify the starting address to be used, to write an application ima...
9 years agoHave you solved this Issue I am running into the same problem. I am assuming that I can just drop the lower 2 bits but I want to make sure.
