MAX10 EPE M9K Fmax limit?
Thiery,
Is it possible for you to attach a small test case for me to replicate it?
I can see there is limitation discrepancy information.
SyafieqS,
It's not possible for me to send you my project. But I've attached some screenshots of discrepancy informations in TimeQuest :
Report all summaries show a few error on minimum pulse width , but it's ok:
OVERCLOCK_VIDEO have positive slack in setup and hold (so it's ok):
and Fmax summary show a limitation on 'OVERCLOCK_VIDEO', setted at 320MHz using PLL, but with restriction at 250MHz (according the datasheet value):
So my points are :
1°) there is a Fmax violation (320MHz >> 250MHz max allowable frequency), without underline in red. why? Isn't it a timing error?
It doesn't appear in 'report all summaries', neither in 'report top failing path'.
2°) the M9K datasheet limitation is 250MHz. This limitation is increased to 260MHz in Early Power Estimator .xls import macro. Why? is it a typo in EPE?
Thanks for your feedback.
