SZand
7 years agoMAX10 dual configuration use only Image in CFM1
Hi, I am using the 10M16SAE144 with dual compressed images, but regadless of the state of the CONFIG_SEL pin, config is done all the time from CFM1. Both images are valid. I had changed the images v...
SZand
7 years agoHi MShafiq,
Thanks for your answer.
I use the HW-pin of the device with a jumper (with 10k pull down resistor / 1k pull up resistor). The logic level change is ok (0.1V / 3.0V). Already changed the device, it is the same.
Best regards
