SZand
7 years agoMAX10 dual configuration use only Image in CFM1
Hi, I am using the 10M16SAE144 with dual compressed images, but regadless of the state of the CONFIG_SEL pin, config is done all the time from CFM1. Both images are valid. I had changed the images v...
ShafiqY_Intel
7 years agoHi SZand,
When you said “regardless of the state of the CONFIG_SEL pin,” can you explain how do you change the state of the CONFIG_SEL pin? Is it using Hardware (change the switch on your board) or Software (using dual boot IP core)?
If you using software, make sure you are using offset 1 (refer attachment picture). Then you need to assert config_sel_overwrite and config_sel in order to make a change. If you want to load the image from:
CFM0 = write 2b’01 (or 0x01 in hex)
CFM1 = write 2b’11 (or 0x03 in hex)
I hope this will help you. Thanks
- ShafiqY_Intel7 years ago
posted a file.
