EEren
7 years agoMAX10 Dual Boot Problem.
In the bootloader project I create a pof file with two sof files. The first sof file - the bootloader project, the second one - the main project. At the same time I generate rpd files. From version...
SreekumarR_G_Intel
7 years agoCan I know your quartus version ? also can you try below link for the converted rpd file
https://www.intel.la/content/www/xl/es/programmable/support/support-resources/knowledge-base/component/2018/while-loading---cof-file--during-rpd-file-creation--in-quartus--.html
There is issue in the quartus 18.0 and 18.1 version that RPD endianness settling not loading correctly.
Thank you ,
Sree
- EEren7 years ago
My version is 16.0. If I set Little endian - I see the difference while comparing register values - burned with a pof and burned with a rpd.
