EEren
8 years agoMAX10 Dual Boot.
On CFM0 I have a bootloader. I create rpd file from a main project and burn it on CFM1. After successful burning I switch BOOT_SELECT to boot from CFM1. However the main project failed to run and ...
AnandRaj_S_Intel
8 years agoHi,
- Bit reversal is required if you have used little-Indian option while generating the .pof file. Which is default.
- If Big-Indian option is used bit reversal is not required
- Example design is attached
Anand Raj Shankar
