jozephka99
Contributor
5 years agoMAX10 Discerete RSU(Remote System Upgrade) Implementation
I have questions about RSU. I want to do a remote system upgrade discrete implementation (without Nios II) with uart. I watched the Intel's RSU course but I can't built the RSU anyway. I do th...
茫于000
5 years ago我使用的是单镜像非压缩模式,IP生成的时候选择这个项目,在编译工程里的器件里选择内部下载配置,也选择单镜像非压缩模式。生成的pof下载文件转换成rpd格式。
记住程序只能下载到CFM里,一般是SECTOR4和SECTOR5,所以这两个块都得配置成读写。然后就把要下载的rpd数据通过AVMM接口写入到CFM里,注意waitrequest信号的控制,写的时候拉高,写完后拉低再更新下一个要写的数据。 还要注意大小端,rpd文件里以hex格式打开后,字节需要按照bit更换大小端。
jozephka99
Contributor
5 years agoI can't understand your message. What language is this?
- 茫于0005 years ago
where are you from ? I'm chinese.
- jozephka995 years ago
Contributor
Why don't you use English?
