kw_arrow
7 months agoMAX10 DDR3 Timing
Hi, I need a definitive statement regarding the timing. The two attached screenshots were created with Quartus 23.1 but can also be found in 25.1. Although adjusting the temperature range reduced t...
kw_arrow
6 months agoHi Adzim,
Unfortunately, the problem has not been resolved even with the references to the manuals on timing. An AI analysis of the failing DDR3 timings states:
"This is not a 'real' logic timing error but rather a classic DDR-DQS analysis artifact in the MAX10."
This is justified based on the following three points:
1️⃣ DQS is treated as a normal clock
Quartus interprets:
"A normal register is clocked by a normal clock (mem_dqs_l_n_OUT)"
❌ This is incorrect for DDR.
In reality:
- DQS is not a global clock.
- DQS is a source-synchronous strobe.
- Capture happens in the I/O element, not in the core logic.
👉 Timing between pll_clk → mem_dq → dqs is physically coupled but not logically synchronized.
2️⃣ The clock skew is absurdly high (6.891 ns)
This is the second major red flag 🚨:
- Clock Skew: 6.891 ns
- Setup Relationship: 0.833 ns
➡️ Quartus compares:- PLL clock in the core
- Against DQS, which comes from an I/O path.
This has no real significance for DDR reads.
3️⃣ PLL compensation appears negative
- PLL Compensation: -7.957 ns / -8.063 ns
This is typical for:- Generated clocks
- DDR IP
- DQS paths
➡️ The timing engine is being used outside its optimal range.
Can we use these statements to arrive at a solution?
