fogl
6 years agoMax10 conf_done stays low
Hello everybody,
I am having problems with Max10 configuration. After I successfully program the fpga the conf_done pins stays low. Actually the conf_done pin goes high for a moment at the beginnin...
fogl
6 years agoNow I also set the DevCLRn and DEV_OE to tri-state input with a weak pull-up. But still the same.
I have got no more ideas.
fogl
6 years agoHello,
Let me answer to myself
Klemen
- ShafiqY_Intel6 years ago
Hi fogl,
Thank you for let's Intel FPGA community here know the solution/answer.
Yes, some time the unstable power rail might cause an issue to FPGA pins. And worst part is when the pin is the Configuration pins(cause failure to configuration)
Matt
