MS's avatar
MS
7 years ago
MAX10: combining analog and digital I/O in same bank possible?
testing with MAX10 (having internal ADCs available), I tried to combine in a given I/O bank analog input pins and (almost) static digital I/Os. Quartus currently prevents me from doing that and throws an error message. Obviously I took care to select a unused analog-capable pin for the digital I/O.
Do I do something wrong or is it really not possible to combine analog and digital I/O in the same bank?
Best wishes,
MS
  • JonWay_altera's avatar
    JonWay_altera
    Hi @MS, it seems you have found the answer to your question. Is there anything else we can help?
    • MS's avatar
      MS
      Hi JwChin,
      Right now I don't need any help any more. The question is answered. Thank you!
      Best wishes,
      MS
  • LZhan65's avatar
    LZhan65
    when you say analog, you mean some signals like lvds?
    to receive analog signals, because you need to maintain the signal quality (linearity, for example), you need analog transceivers in fpga, so you have to use the high speed transceiver banks.
    • MS's avatar
      MS
      HI,
      "analog" here means "ADC input signal". There's nothing high speed about that signal.
      Best wishes,
      MS
