LZhao20
7 years agoMAX10 CFM writing speed
Hi my project is on 10M08SA, and i try to write *.rpd data into CFM using SPI or UART to update the firmware without Nios. the UG_M10UFM says that in the IP Onchip_flash each 32-bit data could take...
a_x_h_75
Contributor
7 years agoUnfortunately, the FLASH write time is a function of the MAX 10 process, not any code. So, no. There's no way to speed up the write to FLASH.
Cheers,
Alex
