11 years agoMAX10 can't accept 125 MHz clock without timing violations
Hi. I'm using quartus 15.0.0 64-bit on Windows 7 pro. I'm working on a design that uses an MAX10 (10M08SAU169C8). The design calls for two clock domains. The first is 50 MHz and the second is...
11 years agoThis looks like it is something to due with the ADC timing requirement. I modified you design and removed the ADC and it works fine. The design looks like the clock is only going to the PLL, so I don't understand why the ADC timing is involved, but I would send your design to the mysupport area of Altera, and see if they can tell you if it's a tool issue.
I have a design that is running > 162 MHz in Max 10 but I'm not using the ADC and I'm using the dual supply part. Pete
