MAX10 bitstream encryption (rbf/rpd)
Hi there.
I'm trying to generate an encrypted .rbf/.rpd file.
I've successfully done the .pof file encryption process, but I don't find any information about encrypted .rbf/.rpd file.
Is it an option to do that process?
Asaf
- rt52
Sorry for digging up an old problem. Did you end up getting this working? I am running into the same issue where the encrypted .pof will program correctly but the .rpd generated in the same step as the encrypted .pof with the same key will not work when downloading the .rpd
- YuanLi_S_Intel
Hi Eyal,
POF is the only programming file that can be used. For dual configuration, you may add 2 SOF (2 design) during the generation of POF file.
Thank You.
Bruce
- Eyal
Hi Bruce,
We need it for Remote Update option (i.e. POF cannot be used).
Kindly verify if encrypted RBF can be used ?
Thank you in advance.
Eyal
- YuanLi_S_Intel
No, we can only program encrypted POF.
Bruce
