8 years ago
MAX10 and Flash Update module
I created Flash Update module with Qsys
    onchip_flash_0 : component altera_onchip_flash
        generic map (
            INIT_FILENAME                       => "",
            INIT_FILENAME_SIM                   => "",
            DEVICE_FAMILY                       => "MAX 10",
            PART_NAME                           => "10M50DAF484C7G",
            DEVICE_ID                           => "50",
            SECTOR1_START_ADDR                  => 0,
            SECTOR1_END_ADDR                    => 8191,
            SECTOR2_START_ADDR                  => 8192,
            SECTOR2_END_ADDR                    => 16383,
            SECTOR3_START_ADDR                  => 16384,
            SECTOR3_END_ADDR                    => 114687,
            SECTOR4_START_ADDR                  => 114688,
            SECTOR4_END_ADDR                    => 188415,
            SECTOR5_START_ADDR                  => 188416,
            SECTOR5_END_ADDR                    => 360447,
            MIN_VALID_ADDR                      => 0,
            MAX_VALID_ADDR                      => 360447,
            MIN_UFM_VALID_ADDR                  => 0,
            MAX_UFM_VALID_ADDR                  => 16383,
            SECTOR1_MAP                         => 1,
            SECTOR2_MAP                         => 2,
            SECTOR3_MAP                         => 3,
            SECTOR4_MAP                         => 4,
            SECTOR5_MAP                         => 5,
            ADDR_RANGE1_END_ADDR                => 360447,
            ADDR_RANGE1_OFFSET                  => 2048,
            ADDR_RANGE2_OFFSET                  => 0,
            AVMM_DATA_ADDR_WIDTH                => 19,
            AVMM_DATA_DATA_WIDTH                => 32,
            AVMM_DATA_BURSTCOUNT_WIDTH          => 4,
            SECTOR_READ_PROTECTION_MODE         => 0,
            FLASH_SEQ_READ_DATA_COUNT           => 4,
            FLASH_ADDR_ALIGNMENT_BITS           => 2,
            FLASH_READ_CYCLE_MAX_INDEX          => 5,
            FLASH_RESET_CYCLE_MAX_INDEX         => 7,
            FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX  => 36,
            FLASH_ERASE_TIMEOUT_CYCLE_MAX_INDEX => 10500000,
            FLASH_WRITE_TIMEOUT_CYCLE_MAX_INDEX => 9150,
            PARALLEL_MODE                       => true,
            READ_AND_WRITE_MODE                 => true,
            WRAPPING_BURST_MODE                 => false,
            IS_DUAL_BOOT                        => "False",
            IS_ERAM_SKIP                        => "True",
            IS_COMPRESSED_IMAGE                 => "True"
        port map (
            clock                   => clock,                   --    clk.clk
            reset_n                 => reset_n,                 -- nreset.reset_n
            avmm_data_addr          => avmm_data_addr,          --   data.address
            avmm_data_read          => avmm_data_read,          --       .read
            avmm_data_writedata     => avmm_data_writedata,     --       .writedata
            avmm_data_write         => avmm_data_write,         --       .write
            avmm_data_readdata      => avmm_data_readdata,      --       .readdata
            avmm_data_waitrequest   => avmm_data_waitrequest,   --       .waitrequest
            avmm_data_readdatavalid => avmm_data_readdatavalid, --       .readdatavalid
            avmm_data_burstcount    => avmm_data_burstcount,    --       .burstcount
            avmm_csr_addr           => avmm_csr_addr,           --    csr.address
            avmm_csr_read           => avmm_csr_read,           --       .read
            avmm_csr_writedata      => avmm_csr_writedata,      --       .writedata
            avmm_csr_write          => avmm_csr_write,          --       .write
            avmm_csr_readdata       => avmm_csr_readdata        --       .readdata
In oreder to have two images - bootloader(CFM0) and main program(CFM1-CFM2) - I need Dual Compressed Images.
So I set - Assignments -> Device -> Devise and Pin Options -> Configuration -> Dual Compressed Images
And generics in Flash Update module I set
IS_DUAL_BOOT        => "True",
When I compile I get an error
--- Quote Start ---
Error (169130): Configuration mode specified as Remote but remote update block is not found in design
--- Quote End ---
If I set Assignments -> Device -> Devise and Pin Options -> Configuration -> Single Compressed Image
And generics
It compiles without error.
And generics
I get an error
--- Quote Start ---
Error (14740): Configuration mode on atom "bootloader:U_BOOTLOADER|flash_update:U_FLASH_UPDATE|altera_onchip_flash : nchip_flash_0|altera_onchip_flash_block:altera_onchip_flash_block|ufm_block" does not match the project setting. Update and regenerate the Qsys system to match the project setting.
--- Quote End ---
How can I compile for Dual Compressed Images?
    --- Quote Start ---
    As it says, you need to have the RSU block in your design to use dual compressed images. See these online trainings:
    https://www.altera.com/support/training/course/omaxrsu101.html
    https://www.altera.com/support/training/course/omaxrsu102.html
    --- Quote End ---
    I see. Thank you.
    Well...I created Altera On-Chip Flash module and Altera Dual Configuration module.
    component flash_update is
        port (
            clock                   : in  std_logic                     := '0';             --    clk.clk
            avmm_csr_addr           : in  std_logic                     := '0';             --    csr.address
            avmm_csr_read           : in  std_logic                     := '0';             --       .read
            avmm_csr_writedata      : in  std_logic_vector(31 downto 0) := (others => '0'); --       .writedata
            avmm_csr_write          : in  std_logic                     := '0';             --       .write
            avmm_csr_readdata       : out std_logic_vector(31 downto 0);                    --       .readdata
            avmm_data_addr          : in  std_logic_vector(18 downto 0) := (others => '0'); --   data.address
            avmm_data_read          : in  std_logic                     := '0';             --       .read
            avmm_data_writedata     : in  std_logic_vector(31 downto 0) := (others => '0'); --       .writedata
            avmm_data_write         : in  std_logic                     := '0';             --       .write
            avmm_data_readdata      : out std_logic_vector(31 downto 0);                    --       .readdata
            avmm_data_waitrequest   : out std_logic;                                        --       .waitrequest
            avmm_data_readdatavalid : out std_logic;                                        --       .readdatavalid
            avmm_data_burstcount    : in  std_logic_vector(3 downto 0)  := (others => '0'); --       .burstcount
            reset_n                 : in  std_logic                     := '0'              -- nreset.reset_n
    end component;
    component altera_dual_config is
    port (
            avmm_rcv_address   : in  std_logic_vector(2 downto 0)  := (others => '0'); -- avalon.address
            avmm_rcv_read      : in  std_logic                     := '0';             --       .read
            avmm_rcv_writedata : in  std_logic_vector(31 downto 0) := (others => '0'); --       .writedata
            avmm_rcv_write     : in  std_logic                     := '0';             --       .write
            avmm_rcv_readdata  : out std_logic_vector(31 downto 0);                    --       .readdata
            clk                : in  std_logic                     := '0';             --    clk.clk
            nreset             : in  std_logic                     := '0'              -- nreset.reset_n
    end component;
    But I completely didn't understand how to connect between these two modules.
    --- Quote Start ---
    Have you set the correct parameter setting of Nios ll and on-chip ram?
    Delete the incremental_db and db folder and recheck.
    Refer the document for steps.
    http://caxapa.ru/thumbs/592124/an730.pdf
    Anand Raj Shankar
    --- Quote End ---
    I don't have NiosII in my project. It's QSYS generated core.
    I go Tools->IP Catalog->Library->Basic Functions->On Chip Memory->Altera On-Chip Flash.https://alteraforum.com/forum/attachment.php?attachmentid=15108&stc=1
    I deleted the incremental_db and db folder - it didn't help.
    Anand Raj Shankar
