8 years agoMAX10 ADC TSD offset - IO bank 8 voltage?
Hi I am using a dual-supply MAX10 device with the onboard ADC configured to estimate the FPGA's temperature using the internal TSD. The ADC also estimates board temperature using an analogue T...
ETroi1
6 years agoHi Tim and Anand
I am currently having the same problem as described by Tim, where the internal temperature sensor is reporting to low temperature.
Before I add more details, did you ever figure out what caused the problem? Were you able to solve it?
Best regards
Erlend
