MikeCO's avatar
MikeCO
2 years ago
MAX10 ADC in DD option
I am using a MAX 10M50DDF256 in a design and using the ADCs. The documentation states that the ADC are available in both the DD and the DA parts. However, when I try to run the design in Quartus Prime Lite I get an error that the ADCs are not supported in the DD option. If I change the device to the DA option, then the Quartus doesn't error.
Is this an Quartus Prime Lite issue or are the ADCs not supported in the DD option, contrary to the documentation?
If it is a Quartus Prime Lite issue, can I use the DA option in Quartus but program a DD part?
Thanks in advance.
  • MikeCO's avatar
    MikeCO
    Another one of our users was able to apply the patch for the Windows version and it works for him. Thanks for the help.
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    Please check your inbox as I am contacting you to get your details if you are interested to get with the patch file. However, for your information, the permanent fix is targeted to being implemented in the future release of Quartus Prime.
    Aqid
    AqidAyman_Altera
    However, we can only help to provide you with the patch for Standard version. Can you consider upgrading to Standard version?
    AqidAyman_Altera
    I would like to update with you regarding this case. Max 10 "DD" variant should support ADC feature same as Max 10 "DA".
    This error has been confirmed to be fix and it will be implemented in future release of Quartus Prime.
    Aqid
    • MikeCO's avatar
      MikeCO
      Thank you for the answer.
      We are using Quartus Prime Lite. Can we get a patch to allow us to continue our development with the DD device and use the ADCs?
    AqidAyman_Altera
    I have got several cases on this issue. Right now, I am working with the internal team to have a look into this urgently.
    I will update you back once there is any update.
    Aqid
