Max10 3.3V Differential Input
As far as I know, there is no .ini that can be used to enable LVDS with 3.3v VCCIO. To use that clock, I would suggest adding external circuitry to lower the common mode voltage plus the swing. I would not recommend using those voltage levels directly to LVDS buffers, because I think this is an out-of-spec situation and even if it works, we can't be sure that it will work all the time and for how long it will work. Also, I believe that if the VCCIO of the bank is set to 3.3v and you assign LVDS to one of the pins, Quartus will not compile successfully. Another option is to change the VCM from the third-party chip. Some chips are able to change that value using some registers.
- RS_CEI1 year ago
Hi AqidAyman! Thanks for the reply.
Design definitely doesn't compile with LVDS (or any differential assignment) on 3.3V VCCIO bank. So you are saying there are two options here:
- Adding external circuitry to lower common mode voltage plus swing.
- Changing the VCM of the IC sending the clock.
I can DC Block and change the VCM/Swing before the Max10 using external circuitry, but I'm not sure how either of these will allow us to use the differential clock in a 3.3V VCCIO bank.
- FvM1 year ago
"So you are saying to change Quartus bank voltage to 2.5V and assign LVDS25? The datasheet specifications on the recommended bank voltage has a maximum of 2.625V (for VCCIO 2.5V) how do you know this will not damage or shorten the life of the part? I would assume the LVTTL/LVCMOS would stay at 3.3V with an actual bank voltage of 3.3V, but are there parts that could get damaged if it is expecting 2.5V I/O?"
As stated, operation is beyond datasheet specs, so I can't guarantee anything. I just mention that it's possible in practice.
Related to output operation, assigned I/O standard is a rule which output transistors out of the available set with different area are activated. With 3.3V actual supply, only smaller current strengths should be enabled although nominal 2.5V VCCIO would allow for larger values. That's particularly important important when driving heavy loads, either resistive or capacitive. IBIS files tell about expectable loaded output current of different I/O standards. Based on this information I conclude that there's no specific risk of operating a 2.5 V output standard with low drive strength at 3.3 V VCCIO.
Related to differential receiver operation there's no useable info in datasheet or device handbook. I can tell that it works, I didn't yet experience damage in 3.3 V operation. Measured common mode range is 0 to 3.3 V, but I don't know worst case margins. Specifically I don't know if there's anything inside the differential buffer that might be overstressed with 3.3 V supply but I won't expect. Surely devices are not production tested under this conditions, so you can hardly expect an official statement approving this operation.
Frank
