9 years agoMAX10 10M50SCE144C8G trouble on programming
part 10M50SCE144C8G on custom board first time got programmed, it was working with an issue, corrected the core never load again on device. Quartus Lite 15.1 Quartus Lite 16.1 won't c...
8 years agoHi rromano001,
Perhaps, you can try to use the latest Quartus stand alone programmer v17.0. You don’t need to install the full Quartus v17.0 version. You only need to install the stand alone programmer. Then you can try to erase the MAX 10 CFM/UFM block and reprogram your .pof file. https://dl.altera.com/17.0/?edition=standard&platform=windows&download_manager=dlm3&product=qprogrammer#tabs-4 Since you are using E144 package device, make sure the exposed pad on the MAX10 E144 package connected to the ground plane on your board. Regards, nyusof (This message was posted on behalf of Intel Corporation)
