9 years agoMAX10 10M50SCE144C8G trouble on programming
part 10M50SCE144C8G on custom board first time got programmed, it was working with an issue, corrected the core never load again on device. Quartus Lite 15.1 Quartus Lite 16.1 won't c...
8 years agoHi rommano,
I have a similiar case with M16SAE144C8G with custom board. As you explained the device can be detected always. Program as SOF say it 100 % (Succesful) but doesn't seem work. Program as POF say failure at 0% verify, blank check say failure at 0% Examine take a long time with progressing bar incrementing 1% every second/ two or more then say 100 % (Succesful) Did you find any solution for this issue?
