9 years agoMAX10 10M50SCE144C8G trouble on programming
part 10M50SCE144C8G on custom board first time got programmed, it was working with an issue, corrected the core never load again on device. Quartus Lite 15.1 Quartus Lite 16.1 won't c...
9 years ago --- Quote Start --- I did not understand "first time got programmed, it was working with an issue, corrected the core never load again on device." What was the issue? Did you check the power supplies? --- Quote End --- Hi sherif123, you asked me to check the power supply, is this general request or you experienced something on PSU behaviour? PSU is on board, can deliver [email protected] 3A peak, it feed just MAX10, a 50MHz oscillator, 3 i2C expander, power LED and an SRAM, board is 4 layer with solid ground and power plane under ETQFP, an additional ground plane is under case to help raise down impedance and also transfer away heat. Some more idea about? Thank
