9 years agoMAX10 10M50SCE144C8G trouble on programming
part 10M50SCE144C8G on custom board first time got programmed, it was working with an issue, corrected the core never load again on device. Quartus Lite 15.1 Quartus Lite 16.1 won't c...
9 years agoConsole output:
Erase Jtagen High Info (209060): Started Programmer operation at Mon Feb 6 23:35:46 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209044): Erasing MAX 10 configuration device(s) Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Feb 6 23:35:46 2017 low Info (209060): Started Programmer operation at Mon Feb 6 23:36:14 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209044): Erasing MAX 10 configuration device(s) Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Feb 6 23:36:15 2017 Program SOF Jtagen High/Low Info (209060): Started Programmer operation at Mon Feb 6 23:37:14 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Feb 6 23:37:23 2017 Info (209060): Started Programmer operation at Mon Feb 6 23:37:54 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Feb 6 23:38:02 2017 Blank check Jtagen High Info (209060): Started Programmer operation at Mon Feb 6 23:38:47 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209060): Started Programmer operation at Mon Feb 6 23:38:48 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Feb 6 23:38:57 2017 Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Feb 6 23:38:57 2017 Jtagen Low Info (209060): Started Programmer operation at Mon Feb 6 23:40:20 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209060): Started Programmer operation at Mon Feb 6 23:40:21 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Error (209014): CONF_DONE pin failed to go high in device 1. Make sure all communication cables are securely connected, select a different device, check the power on the target system, or make sure all nCE pins are connected to GND. The Altera Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number. Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Feb 6 23:40:29 2017 Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Feb 6 23:40:29 2017 Info (209060): Started Programmer operation at Mon Feb 6 23:40:57 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209060): Started Programmer operation at Mon Feb 6 23:40:57 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Error (209014): CONF_DONE pin failed to go high in device 1. Make sure all communication cables are securely connected, select a different device, check the power on the target system, or make sure all nCE pins are connected to GND. The Altera Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number. Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Feb 6 23:41:06 2017 Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Feb 6 23:41:06 2017 Examine JTAG low Info (209060): Started Programmer operation at Mon Feb 6 23:41:50 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209038): Examining devices Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Feb 6 23:48:15 2017 program POF JTAGEN low nCONFIG HIGH Info (209060): Started Programmer operation at Mon Feb 6 23:50:13 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209060): Started Programmer operation at Mon Feb 6 23:50:14 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Error (209014): CONF_DONE pin failed to go high in device 1. Make sure all communication cables are securely connected, select a different device, check the power on the target system, or make sure all nCE pins are connected to GND. The Altera Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number. Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Feb 6 23:50:23 2017 Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Feb 6 23:50:23 2017 Nconfig Low Info (209060): Started Programmer operation at Mon Feb 6 23:50:53 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209060): Started Programmer operation at Mon Feb 6 23:50:54 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Feb 6 23:51:02 2017 Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Feb 6 23:51:02 2017 Info (209060): Started Programmer operation at Mon Feb 6 23:52:01 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209060): Started Programmer operation at Mon Feb 6 23:52:02 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Feb 6 23:52:10 2017 Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Feb 6 23:52:10 2017 second attempt erase program Info (209060): Started Programmer operation at Mon Feb 6 23:52:40 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209044): Erasing MAX 10 configuration device(s) Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Feb 6 23:52:40 2017 Info (209060): Started Programmer operation at Mon Feb 6 23:52:47 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209060): Started Programmer operation at Mon Feb 6 23:52:47 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Error (209014): CONF_DONE pin failed to go high in device 1. Make sure all communication cables are securely connected, select a different device, check the power on the target system, or make sure all nCE pins are connected to GND. The Altera Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number. Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Feb 6 23:52:56 2017 Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Feb 6 23:52:56 2017
