9 years agoMAX10 10M50SCE144C8G trouble on programming
part 10M50SCE144C8G on custom board first time got programmed, it was working with an issue, corrected the core never load again on device. Quartus Lite 15.1 Quartus Lite 16.1 won't c...
9 years ago --- Quote Start --- I did not understand "first time got programmed, it was working with an issue, corrected the core never load again on device." What was the issue? Did you check the power supplies? --- Quote End --- On IP core one signal was at default, iIPCORE display on an LCD two different windows. Due to this error on LCD an image was present where it was expected to be blank, after correcting design was never possible to load again an image to device. About power supply, I can test it, LCD is lit on, on previous an image was present, after erase was no more possible load core so no image is on display. I see report from console got lost, so I post again a new one.
