9 years agoMAX10 10M50SCE144C8G trouble on programming
part 10M50SCE144C8G on custom board first time got programmed, it was working with an issue, corrected the core never load again on device. Quartus Lite 15.1 Quartus Lite 16.1 won't c...
9 years agoConsole output:
Examine: Info (209060): Started Programmer operation at Sun Feb 5 22:54:28 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209038): Examining devices Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Sun Feb 5 23:00:56 2017 program configure POF Info (209060): Started Programmer operation at Sun Feb 5 23:02:39 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209060): Started Programmer operation at Sun Feb 5 23:02:40 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Error (209012): Operation failed Info (209061): Ended Programmer operation at Sun Feb 5 23:02:41 2017 Error (209012): Operation failed Info (209061): Ended Programmer operation at Sun Feb 5 23:02:41 2017 ERASE Info (209060): Started Programmer operation at Sun Feb 5 23:06:06 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209044): Erasing MAX 10 configuration device(s) Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Sun Feb 5 23:06:06 2017 Program SOF NConfig High: Info (209060): Started Programmer operation at Sun Feb 5 23:06:06 2017 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209044): Erasing MAX 10 configuration device(s) Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Sun Feb 5 23:06:06 2017 NConfig Low: Info (209060): Started Programmer operation at Sun Feb 5 23:10:54 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Sun Feb 5 23:11:03 2017 Info (209060): Started Programmer operation at Sun Feb 5 23:12:01 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Sun Feb 5 23:12:10 2017 program pof Info (209060): Started Programmer operation at Sun Feb 5 23:13:31 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031850DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Sun Feb 5 23:13:39 2017 Error (209012): Operation failed Info (209061): Ended Programmer operation at Sun Feb 5 23:13:39 2017
