9 years agoMax10 10M08SAU169 Layout, PDN tool required?
Hello, I have a 4 layer board with Max10 10M08SAU169 (Single Power supply, not using the ADC) device. This is a UBGA package with 0.8mm pitch and I am using several vias, in-between the v...
9 years agoMost standard MAX10 designs will work well with a single power plane. Placing as much bypass capacitors as possible is a good idea, though. Capacitors directly on the bottom side is a perfect solution, but not necessarily required. You may prefer single side assembly.
You are mentioning ADC specific points like isolating REFGND.
