TBarn2
8 years agoMAX10 10M04CE using FIR IP
Hi we have a new board design that uses a 10M04CE device. We are experimenting with functionality. We would like to implement an FIR filter and have tried to create one using the FIR II IP in the Qua...
CheepinC_altera
7 years agoHi,
For your information, I am able to compile a FIR II IP in both the 10M04SCE144C8G and an 10M02SCE144C8G part that you are using. As I discussed with the configuration expert, I understand that the compact Max 10 that you are using does not support memory ie ROM initialization. If you have any ROM in your design, it will trigger the errors that you are seeing. Just wonder if you are using any module which require memory initialization ie ROM in your design?
Thank you.
Chee Pin
