9 years agoMAX10 10M02SCE144C8G high current draw
Hello, I recently soldered a MAX10 single 3.3v supply part (10M02SCE144C8G) onto a breakout board to run some experiments with. I connected all the IO supplies to 3.3v successfully loaded a "bl...
9 years agoHello,
Not sure what happened to my first reply. I will try again. Yes the EP was soldered and connected to ground. I measured ~15ohms between VCC_ONE and GND which seems wrong so I took the part off. With it off I also measure 15 ohms so I think I must have damaged the on chip (single 3.3v supply FPGA) regulator when I fitted it the first time. So it does seem the part was damaged and not a pin connection thing. I assume it was heat damage. Chris
