9 years agoMAX10 10M02SCE144C8G high current draw
Hello, I recently soldered a MAX10 single 3.3v supply part (10M02SCE144C8G) onto a breakout board to run some experiments with. I connected all the IO supplies to 3.3v successfully loaded a "bl...
9 years agoHello,
Yes it is an EP adapter board and I confirmed I had a good connection by testing continuity between the ground plane (EP) and other FPGA ground pins before I connected those other ground pins. I measure ~16 ohms accross VCC_ONE to GND which would give me my 200mA+ current draw @3.3v by ohms law. This makes me think I damaged the part rather than it being misconfigured and/or inputs oscillating - but intosc, logic & FLASH work as expected & I have found no damaged function... Chris
