9 years agoMAX10 10M02SCE144C8G high current draw
Hello, I recently soldered a MAX10 single 3.3v supply part (10M02SCE144C8G) onto a breakout board to run some experiments with. I connected all the IO supplies to 3.3v successfully loaded a "bl...
9 years agoHi,
just to mention (as you said, you've soldered the device to a breakout board)... Did you also connect the exposed Pad "below" the package to GND like stated in the PinOut file?
