Max10 - Quartus: no dual boot option avaliable
- 4 years ago
I try myself with the same device and I couldn't see dual options either. Then I search a bit an found it is because 'SC' series of max10 don't support dual features. Probably because of lack of flash elements. The relevant pictures attached below. As you can see SCs very few flash memory compare the others.
I selected the device with Assignments->Device menu. Please see image attached. The Compilation Report also shows the same device after compilation process.
Is there also some other way to select or to check if the device was properly selected?
- fogl4 years ago
I see, thank you for your help
I don't know why is there still a config_sel pin on this device if it has no sense...
Klemen
