9 years agoMAX10 - 10M02DCV36I7G - BOARD - High current draw or shortcircuit ?
Hi all, Target MAX10: 10M02DCV36I7G Quartus: 15.1 We are trying to design a very minimalist and small MAX10 FPGA board using the 10M02DCV36I7G. The schematic (attached) of the board is ...
9 years agoHi sstrell,
Thank you for taking the time to answer. --- Quote Start --- What do you have unused pins set to in Quartus (Device settings -> Device & Pin Options)? --- Quote End --- Currently unused Pins are defined on de default value : "As input tri-stated with weak pull-up". Best Regards Tim
