max v tri-state i/o
Hi, I need to use the tristate i/o feature of max v and can't seem to find the i/o block in the megawizard library.
Anybody know how to use the feature ?8 Replies
--- Quote Start --- I can easily imagine that some obscure command may be necessary to do this. --- Quote End --- I can't remember needing obscure commands for standard logic functionality with Altera Quartus. May be for some very special one. - Altera_Forum
Correct, the netlist shows the assignment it done automatically.
--- Quote Start --- Why don't you just implement a simple circuit and watch the results in the Quartus netlist? Honestly, I can't imagine how Quartus would implement a tri-state driver without connecting the output enable. Can you? --- Quote End --- - Altera_Forum
I can easily imagine that some obscure command may be necessary to do this. And yes, looking at the netlist would probably clarify the issue.
Dave, will the Fitter automatically map my enable signal to the output enable of the i/o block ? Because in the pin assignment editor i don't see an option.
Thanks. --- Quote Start --- Then you would drive the signal with a tri-state that has an output-enable, i.e., in VHDL bidir <= 'Z' when (enable = '0') else output; and you can read bidir as an input at any time; when enable = '0' you are reading what is driven onto the pin by the external device, and when enable = '1', you will read what you are driving on 'output'. You can turn on the 'weak pull-up' or 'bus hold' on the pin for bidir so that it is always in a valid logical state. Cheers, Dave --- Quote End --- - Altera_Forum
--- Quote Start --- I have a pin which is both an input and an output. In certain clock cycles the block reads the value and in others it drives it. --- Quote End --- Then you would drive the signal with a tri-state that has an output-enable, i.e., in VHDL bidir <= 'Z' when (enable = '0') else output; and you can read bidir as an input at any time; when enable = '0' you are reading what is driven onto the pin by the external device, and when enable = '1', you will read what you are driving on 'output'. You can turn on the 'weak pull-up' or 'bus hold' on the pin for bidir so that it is always in a valid logical state. Cheers, Dave - Altera_Forum
What do you mean? An output is usually tristated in behavioral code, e.g. pin <= 'Z'
