10 years agoMAX-V input impedance
Hi all,
I wander what is the IO and CLK input impedance of the MAX-V before first time programming the device? (I don't want the CPLD to disturb the CPU signals that are connected to it). Thanks, Shony2 Replies
--- Quote Start --- Hi, all Altera devices have weak pull-ups, which are enabled until the device enters user mode (i.e. during configuration, etc.). My understanding is that these are also applied while the CPLD is not programmed yet, at least I could not find anything contrary in the manuals. The spec for the MAX V is not as clear as e.g. for Cyclone devices, but as far as I understood it, the weak pull-up resistor depends on the applied I/O voltage, and it can be as low as 5 kOhm. So I'd say as long as all your CPU signals are properly driven (and you don't use any fancy open-emitter outputs), the CPLD should not interfere with the CPU. Best regards, GooGooCluster --- Quote End --- ---------------------------------------------- Thank you GooGooCluster. Shony - Altera_Forum
