10 years agoMAX-V input impedance
Hi all, I wander what is the IO and CLK input impedance of the MAX-V before first time programming the device? (I don't want the CPLD to disturb the CPU signals that are connected to it). T...
10 years agoHi,
all Altera devices have weak pull-ups, which are enabled until the device enters user mode (i.e. during configuration, etc.). My understanding is that these are also applied while the CPLD is not programmed yet, at least I could not find anything contrary in the manuals. The spec for the MAX V is not as clear as e.g. for Cyclone devices, but as far as I understood it, the weak pull-up resistor depends on the applied I/O voltage, and it can be as low as 5 kOhm. So I'd say as long as all your CPU signals are properly driven (and you don't use any fancy open-emitter outputs), the CPLD should not interfere with the CPU. Best regards, GooGooCluster
