8 years agoMAX V CPLD Reset and OE
Hi Guys, I have a problem with the RESET and OE. I noted the MAX V CPLD has assigned pin 44 as DEV_CLR and pin 43 as DEV_OE. I have set pin 44 as my global reset in my design. However, after c...
8 years agoDEV_CLRn and DEV_OE are dedicated configuration pins. You may refer to Max V Pin Connection Guidelines for the information of these 2 pins:
https://www.altera.com/en_us/pdfs/literature/dp/max-v/pcg-01012.pdf
