8 years agoMAX V CPLD Reset and OE
Hi Guys, I have a problem with the RESET and OE. I noted the MAX V CPLD has assigned pin 44 as DEV_CLR and pin 43 as DEV_OE. I have set pin 44 as my global reset in my design. However, after c...
8 years agoI would suggest not using the DEV_CLRn and DEV_OE Pins as these are used during configuration. Try changing the Reset and OE pins to other GPIO and then check. When not using the DEV_CLRn it should be tied high.
