9 years ago
MAX V add pull up resistor for input
Hi Guys,
I'm not sure how to add a pull up resistor for an input pin using Quartus Prime?
I try to find it in Pin planner and assignment, but there is nothing shows to add a pull up resistor.
Thanks!
    You can also enable it using command as below in QSF file
    set_instance_assignment -name WEAK_PULL_UP_RESISTOR ON -to *
    Right, the weak pull-up column need to be enabled before in the right mouse-button "customize columns" context menu.
