TN-Notebooks
3 years agoMax V 5M80ZE64C5N examine / Verify Failure
Hardware Synology Board with 5M80ZE64C5N PL-USB Blaster RCN Rev C Software Win 10 Programmer Standalone Quartus Prime 17.1.1-593 ( all Versions above have a Bug with File save after eami...
WZ2
3 years agoHi there,
I spent some time analyzing your sof. It was found that the part of cfm was corrupted. The reason for this phenomenon may be that some of the flash of the device is damaged, so that all reads are zero (this is usually impossible). Or whether the manufacturer has added some protection methods to the ICB. My final suggestion is to keep nconfig low after powering on, and then do the examination. If the examination still cannot be verified in this way, then you can consider whether it is a hardware failure.
WZ
