Max V 5M80ZE64C5N examine / Verify Failure
Hi there,
I see that you run the EXAMINE successfully, but the verify fails. Is the file generated after you run examine consistent with the original file? If they are consistent, please try to verify again after the examine. At the same time, please remember to check the “Enable realtime ISP to allow….” option.
WZ
- TN-Notebooks3 years ago
I do not have the Original File - thats the Reason why i use Examine
see my Post
@TN-Notebooks wrote:
The Reason for Examine is that i need Clones of the Max V 5M80ZE64C5N
I repair specific Mainboards on Chiplevel and sometimes the Max V is blown for example due to a Short circuit on Board
The Manufacturer of the Boards do not support the original Files so that i can not program on a normal way the new Max V
I need to readout at a donor unit the Flash - the Protection Bit is not set.
I do not need to change anything and do not want to programm anything - i just need clones.
Same behavior with “Enable realtime ISP to allow….” option.
If i programm the Examined Files to a new chip - the Unit do not work. The Files are corrupted.
Verify tells the Truth with the Message "Failed"
