Max V 5M80ZE64C5N examine / Verify Failure
Hi there,
I see the reason. You don’t wanna use ASMI ip or anything, the examine is the simplest way to do such thing. I try DK-DEV-5M570ZN and quartus 20.4 and there is no error. Could u try to do the examine?
WZ
- TN-Notebooks3 years ago
Hallo
Same Failure / Behavior with 20.4 see Screenshoot
Info(209060): Started Programmer operation at Fri Sep 1 13:26:23 2023
Info(209017): Device 1 contains JTAG ID code 0x020A50DD
Info(209018): Device 1 silicon ID is ALTERA10-1
Info(209038): Examining devices
Info(209011): Successfully performed operation(s)
Info(209061): Ended Programmer operation at Fri Sep 1 13:26:24 2023
Info(209060): Started Programmer operation at Fri Sep 1 13:27:24 2023
Info(209021): Performing verification on device(s)
Info(209061): Ended Programmer operation at Fri Sep 1 13:27:25 2023
Info(209060): Started Programmer operation at Fri Sep 1 13:27:29 2023
Error(209048): Verify failure on device number 1
Error(209012): Operation failed
Info(209061): Ended Programmer operation at Fri Sep 1 13:27:30 2023
