Max V 5M80ZE64C5N examine / Verify Failure
Sorry for the late reply due to the holiday. This problem is indeed more troublesome. Do you want to verify the consistency of the content in the flash and the content in the cram when you do verify? What is the reason for doing the examine?
Knowing your purpose, I might be able to give better advice~
WZ
- TN-Notebooks3 years ago
The Reason for Examine is that i need Clones of the Max V 5M80ZE64C5N
I repair specific Mainboards on Chiplevel and sometimes the Max V is blown for example due to a Short circuit on Board
The Manufacturer of the Boards do not support the original Files so that i can not program on a normal way the new Max V
I need to readout at a donor unit the Flash - the Protection Bit is not set.
I do not need to change anything and do not want to programm anything - i just need clones.
